Installing full wheel well liners - need input
Jeff B
picked the full size liners yesterday from dealer . Asked for the extra screws , mine doesn't have the flares on bed sides. Question after watching the install videos, ...mine doesnt have the U clips on top everyone is using on the inside back holes ? Should I purchase a few from dealer
I took the U clips off the mini liners that get removed when the full liner is installed
They are built into the upper side of the liners you bought. The screws go right through the wheel opening lip and tighten on the clips that are installed on the liner from the factory. You only need to remove one from the rear bottom of the part you separate at the back, and install it in the lower hole behind the wheel that is missing one. No new Uclips are needed. If you need help let me know.
Okay..the videos showed adding 2 along back wall those are ones I thought I'd need
Thanks
