Inner wheel clearance?
aadesh56
Hi,
I'm looking to find some measurements on what the minimum inner wheel diameter be. I'm looking for a square set of 18s that will fit over the stock PP brake calipers. From my rough measurements, the radius of the center to the edge of the front brake caliper is about 20cm. So 40cm for the diameter, plus 6-10mm for the gap clearance (just to be on the safe side). So the minimum inner diameter would be ~41cm (about 16.15 inches). Does that sound about right to you all?
192.168.2.1
192.168.0.1
192.168.1.128
