Inner and outer Tie Rod End Torque Spec 2019 Ram 1500 DT
gotnas
Does anyone know the inner and outer tie rod end torque spec's? It's a 2019 ram 1500 DT I can't find it anywhere and Haynes online manual I bought just has a web page error on it. I have it back together just need the torque specs. This is my only vehicle any help is appreciated.
For 5th Gen Ram 1500 (2019-2024) tie rod replacement, the inner tie rod nut should be torqued to 125 ft-lbs, and the outer tie rod end nut should be torqued to 78 ft-lbs. Additionally, the tie rod end adjuster clamp bolts should be tightened to 45 ft-lbs, according to CarParts.com.
Detailed Breakdown:
Important Notes:
  • Always consult your vehicle's specific repair manual for the most accurate torque specifications.
  • These specifications are for the 5th generation Ram 1500 (2019-2024) and may differ for other models or years.
  • Consider having your vehicle's alignment checked after replacing tie rod ends.
