Ignition goes from Run to Acc when cutting truck off after stop
Magicmo1
When I go to turn my truck engine off. I press the push button and instead of turning off, it goes to Acc. And sometimes when I press the button again it goes back to Run. And then to off.
Sometimes when I go to start the engine, put my foot on the break pedal. Press start. It will not start but goes to run.
Anyone else have this issue.
I haven't heard of that before. If the behavior of the button is inconsistent like you describe, then it sounds like there's some kind of short in the button. They're pretty cheap (and easy) to replace. I'd just buy another one and be done with it. You could even upgrade to the red TRX-style start button while you're at it.
Mine does this as well, yet to figure out why.
mine does this. tried new button, didnt help. tried new fob, didn't help. changing the body control module Wednesday.
Not sure if it's the same thing, but several times I've parked my truck, hit the button to turn it off, go to open my door and the radio stays on even though I expected it to turn off when I opened the door. I look at the button and the acc is lit, so I cycle it through to off. I've attributed it to maybe not hitting the button quick enough, holding it a tad too long.
