How to disable or enable the horn beep with keyfob
Bo3liwe
Kuwait
hi
how to disable or enable the horn beep on your ram when lock or unlock doors (with keyfob) without use uconnect 12 inch?
because I have only this option flash when unlock or lock the doors on uconnect 12inch20190306_225548.jpg
Right below the “flash lights” is(should be) the sound horn options on that same screen
I don't have this option.. the car and uconnect come without that option.. i am from KUWAIT.. AND ALL DODGE CARS DON'T HAVE THIS OPTION ON MY COUNTRY
Sooo, if you know it's not an option, why are you looking for it?
Some time i want to know if the car on the range of keyfob or not.. so if i hear the horn beep i will know
General consensus is that it should be done through Uconnect on 2013 and up vehicles. If you can't find it there, then you can try searching for the old way of doing it with the key fob, there's a ton of Youtube videos out there on it.
Looks like the arrow is pointing up on the flash lights with lock icon, if you press that the arrow should point down and you should get more options to pick from.
