How to add a subwoofer to UConnect 12 with Alpine System
craulston
Not sure if this has been posted before, if it has apologies in advance.
I messed with this for some time until I found the right T-Harness.
The PAC APC-CH03 is needed. PAC APC-CH03
It comes with 3 harnesses.
The TWO that are needed are:
Harnesses A and B (Grey)
Harness C (White)
Out of Harness A\B, you can tap Speaker 3 (Yellow), left door for the signal.
Harness C is the ANC bypass.
You can go into an AMP that accepts direct signal or a PAC LP7-2 or something like.
Hope this saves someone some time.
