Horn died, how to replace?
Hemogoblin
Im pretty sure one of them is dead, sounds like a Fiat when I honk now. Im actually surprised it happened, seems early for a horn to die and doing research, it seems this happens relatively frequently? Ive replaced a horn in the past, just wanted to ask for any tips, etc before I get in there.
I initially assumed there may just be some snow or ice in the horn (which is possible will wait until it warms up anyway before tackling this) but I honk at drivers frequently so it is safe to assume it died, LOL
My high note horn died and was replaced under warranty when it did. It's easy to replace. Remove the clips that hold the plastic cover on at the front of the engine compartment. You'll see the horns on the radiator support. Remove and replace. Simple electrical plug in.
Thanks. Do these get replaced as a pair? On the Mopar Parts website, it looks like both horns are on one bracket and they seem to be sold like that.
I don't know if they get replaced as a pair. I didn't check after they were replaced. There are two part numbers and you can separate each from the bracket. If I was out of warranty, I would have bought aftermarket and wired in the horn that needed replacement.
