Hi-Lift mount
TractorM
Saw that Hi-Lift sells a mount that is compatible with the gladiator rail system. Was curious if this would work with the ram rail system. I assume since they are both made by Mopar, they are identical, except obviously, different lengths. But, it should work just the same. 51Bh2YspfiL._AC_SY350_.jpg
Did you end up getting it? I have been trying to research a good mount for when I get my truck.
I've been looking into this and will be buying it off of amazon in the event it doesn't work. Will report back.
I've been looking into this and will be buying it off of amazon in the event it doesn't work. Will report bb
I bought the kit for the Toyota rails, it was open box and about $40 cheaper than the Jeep ones. Works perfect, just had to trim the bolts down 3/8" because they bottomed out on the back of the rail. I have a post about it in the off road section.
