Was installing the passive entry and when pulling out the door connector I broke a wire, looks to be purple and white. Can anyone please tell me how to fix and what that wire is for?
No idea what the wire is for, but along the lines of what MannyN wrote, you could try something like https://www.amazon.com/dp/B07S62KYSL remove a little bit of the plastic around the broken ends with a wire stripper, put the wires into each end of the wire connector, and use a head gun (a lighter might work?) to melt the solder and shrink the plastic around the wires.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
