Help please! Revel links Air ride level question?
plimmy
I just leveled my 2019 Rebel with the revel links and daystars. I also switched out the UCA’s to the mopar loft arms. Love the ride and all works great. I did notice my links being off in position. Pics are of driver and passenger front. Driver side seems correct, passenger is a little off? Thoughts?
Mine are the same. Hasn’t been an issue thus far
looks dope . what size tire ?
did you do it yourself ? If yes how do you go about disconnecting the air bags
i have a few question and getting different answers i had a 2019 Ram 1500 Laramie with the ORP. When my truck was wreck i traded it for a used 19 Ram Limited 4x4 with the Air . to me the Laramie felt just as smoother then the air on my Limited is this because of the 22 wheels?
Question 2
i planning on getting the links only for leveling and i been hear that the ride is not oem it a little rough. Then i saw someone say to get the spacer with the link and it back to oem?
. and installing big tires 35x12.5x22 or possible going with the aftermarket wheels and tires to a 20inch would it be noticeable change feeling in ride from 22 to 20? tires would be nitto ridge grap.
Question 2
Everything I’ve read says the ride will be better on 20s. I believe the r22 grappler tire in that size is F rated and very stiff.
Question 2
Haven’t driven a non air ride ram but I would think anything with 22‘s and stock height wheel would ride a little rougher due to less sidewall.
That being said I switched from stock 22’s to 20’s and it rode much better in my opinion. then I leveled it initially with links only and found the ride too rough for me as the airbags were pretty inflated to actually level the truck. I would guess it was sitting somewhere between OR1 and OR2 in the front to match the rear. Once I put the spacers on then the airbags didn’t have to inflate as much to achieve the same height thereby bringing the ride back to stock. Make sense ?
I haven’t regretted doing the links and spacers one bit, all my air ride setting work no problem.
Sorry for the delay. I had my shop do it. I did the links but not the spacers. Rides perfect and no issues
@plimmy loosen the bolt attaching the lower sensor part on the frame and straiten that link up! Then tighten it back up!
Are you talking about the torx screw that holds the sensor body to the frame? If so, doesn’t that sensor have a specific orientation that it snaps into? Would like to hear more about straightening it up! Thanks
Loosen the hex bolt and rotate the sensor left or right on the frame.
Great info in the last few posts (this isn't to say the other posts aren't good info too)...
The crooked end links seems to be common... thanks for posting solution bonebro! I'm going to keep this in mind when I finally level.
