jeffrey5679
- Oct 2, 2020
I purchased a set of led headlights w/ retro shop adapters on here to swap out my my halogens. When I installed them,1 side DRL’s and parking light were out. I swapped out the adapter with the grey block on the side that wasn’t working to the other side and the issue seems to follow. Then I plugged both headlights into the working side and everything on both lights worked. Would you agree that the one section with the grey block is bad while the other is good?
