vinnieloo
Hey all,
So i had the dreaded rear window water leak. I think it's the crack in the frame as seen in this thread. Both sides had water dripping in. Headliner was wet drivers side. Intermittent electrical bugs like key FOB not detected or stop/start unavailable.
So i pulled the roof trim off and sealed over the cracks with RTV. However i cracked one of the retaining tabs that holds on the plastic end piece of the trim, drivers side crew cab. Any help finding a replacement is appreciated.
My original window frame had the standard visible cracks.
The replacement developed cracks in the corner that could not be seen from inside.
I would go to a different dealer or... advanced auto and get some permatex flow-able silicone and be done with it.
