So a month ago my coil went bad on #8. Replaced coil and checked both plugs which looked fine. A month goes by and I'm getting same misfire code on 8. Replaced coil again even though it's running ok. Checked plugs and 1 plug was fine but the other is damp. Not sure if it's oil or coolant. Why would 1 be damp but not the other? I can disconnect batt to clear code but comes back within 5 min of driving. Any ideas????
188k on 2019.
188k on 2019.
