Help! AlfaOBD disabled settings
Misfit
Washington
I have a 2023 RAM 1500 Limited 5.7L V8. I am new to using AlfaOBD and I was attempting to modify settings to allow me to turn off the headlights (because this is a Canada model it always has headlights on). From what I understood was changing the country of origin to USA (previously was set to unspecified) this would allow me to access that setting. Well after changing the country of origin I am now getting multiple error messages:
LaneSense and auto high beams disabled
Service air suspension system
Service trailer brake system
Auto emergency brake (AEB) system disabled
And the 360 camera is disabled
I reverted the country of origin back to the unspecified but that did not fix the issue. Any suggestions??
Wish I can help. Ironically I ordered the same Bluetooth odb port and security bypassand just starting to play around with some of the settings. Is there a way to save the default settings before you start screwing around?
2016 Dodge Charger scat pack
There is, something about "save vehicle config. to file"
I saved mine couple of years ago, can`t remember off the bat how to do it.
The alfa obd sub forum has lot of useful info.
