All:
Need some support ASAP. I have a 2019 Ram Big Horn and am installing an aftermarket sub into the truck. I DO NOT have the premium sound system so my thought was that I could just tap into any speaker to get a signal that goes to the amp.
I initially tried to tap into the rear door speaker but ran into a problem when I began to drive the truck and the auto lock feature engages (at 15-20 mph). I would hear a loud "boom" from the sub so I believe that the voltage went down. I also noticed that if I pressed the unlock button on my door, I would continuously get the "boom" from my sub once I pressed it. I then went to Plan B: tapped into the front tweeter. The sub worked perfectly when I turned on the battery/ACC. I also tested the unlock button to see if I would get the "boom" like I did before when I tapped into the rear door speaker - I did not. When I went to turn the actual engine on, however, it instantaneously revs to 4k RPM without touching the accelerator. Any thoughts or suggestions? What is causing this?
Equipment:
-PAC 35 LOC
-8 gauge wiring
-New Rockford Fosgate Amp
-JL Audio Sub
All help is greatly appreciated!!!!
Equipment:
-PAC 35 LOC
-8 gauge wiring
-JL Audio Sub
