Could I ask someone with air suspension and 4x4 with stock tires to please tell me the distance in inches from: 1) ground to interior front floor; and 2) ground to edge of front seat, both when in entry/exit mode? Thank you!
I'll do it, but first:
1. Define and describe the location "interior front door."
2. Which of the several edges of the front seat are you interested in?
The driver side front floor just inside the drivers door, where it starts to flatten out, and the highest edge of the drivers seat toward the drivers door (the area where you sit, not the back support).
All measurements from concrete floor when in Entry/Exit mode. See my sig for model information
These first 3 are fixed, and will always be:
To bottom driver's door - about 16.25 inches
To top of door armrest -about 41.75 inches
To door sill plate - about 21 inches
This last one is gonna be different, depending on seat construction and personal preference.
Also, the seat cushion is gonna be lower in the back than the front, regardless of adjustment.
To front edge of seat at the height I prefer (because you didn't specify) - about 35.5 inches
Consider a trip to the dealership with a measuring tape for any other dimension information you may need.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
