Headlights fuse
Boris
Hello, I have a 2021 Ram 1500, I am trying to install the Silverholder dynamic car hood led strip on the fog lights but I can't find the fuse neither in the manual nor in the fuse box
Not sure if it is true, but from what I have heard, the switch doesn't even turn them on anymore. It just sends a signal to the BCM, and it turns them on. Nothing on newer vehicles is like it was in the old days. It's possible, if you tie in to the circuit, it can cause problems elsewhere. Your best bet is just getting a fuse tap, and tapping into a fuse that is hot when running.
