Headlight upgrades
RonnieJalomo
So I have a 2019 RAM 1500 with the basic halogen headlight assembly and was currently thinking about purchasing the OEM led headlight assembly I believe they will fit but the real question is will it be a simple plug and play or will there be some kind of modification that will be required or will it even work at all
Have to say the LED headlights on these are outstanding. Not sure if you'd need any coding done for the auto leveling and auto high beam functions.
These two threads might help you out -
Thanks for the info
Do you know where to get this wire harness
Found a pair of oem led headlights going to order my wire Harness and hopefully install these boys by next week I have one more question how do you replace the LEDs in these headlights
