Headlight LED Ring -Running Light
J201974
Moyock, NC
One of my headlights has the Running Light not working so I turned them off, but that LED Ring also comes on with the headlights..I don't want it to cause an issue with state inspection so my question is this: Can I turn that LED Ring off for both headlights completely? I was hoping Alpha OBD might be able to switch it off but I have not looked into it yet...Any other ideas? How much is the complete assembly?
Why would the accent LED`s create a problem with the inspection? They are DOT approved headlights. I would not worry about it.
The assembly is over thousand IIRC.
Thanks guys..I will give it a try..worse case I can get into the harness and disable it physically.
The LED strip comes on for about one second then goes off, ....has anyone else seen this and is there a way to fix it other than spending $1000
