I can't for the life of my get this grille off. Is there a trick to it or am I not manhandling it enough? Tried prying upwards with a plastic pry tool but it's just flexing a crap load
These vehicles are designed for quick assembly at the factory, so my guess is that it snaps into place, but I've never replaced the speaker or light sensor that lives there so can't say for sure.
Fresh retainer clips can hold on very well. It is scary pulling up on them when you aren't 100% sure you didn't miss a screw somewhere. Those speaker grills are always held in with retainer clips and if there are some screws they are under the grill and have no effect on the trim piece.
"Remove the speaker grille (1), that contains the sun sensor, from the top of the instrument panel using a trim stick or equivalent"
Yes it takes some force but pops right up.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
