n7qpp
- Nov 17, 2021
I have a 2022 RAM 1500 and just installed the following dual band - VGC VR-N7500. Power is directly from the battery. I have a video so you here the interference noise. This is being generated with the truck in run mode and no engine running. I have tried the following corrective actions:
Here is a link to a video you here the noise
Microsoft OneDrive
- add a snap-on ferrite with a wrap of both the power and antenna leads
- remove the antenna and the noise disapperas
- changed to a different antenna
- moved the antenna to different spots on the truck
- switched out the radio to a ICOM IC-208H-this is the one in the video.
Microsoft OneDrive
