Groan noise at 1200 to 1500 RPM
Dgulia
I have a 2025 Ram 1500 Laramie, from day 1 there is a groaning noise coming from the vehicle when you are at 1200 to 1500 RPM, looks like vehicle is in high gear and need to shift down. Only does it when you are cruising in town around 30 to 40 MPH. If I press the gas it shifts and noise goes away. Also no noise at same RPM on highway cruising. Also no noise when you shift manually.
Took it to the dealer and they performed a TSB update for transmission, it has helped but noise is still there.
Taking it back on next week.
Has anyone experienced this?
Thanks for your help
