glove box noise
Rnowjr
Have a rattle sound coming which seems to be coming from behind the glove box area. has anyone else had this issue and or solution?
Anything fall behind the glovebox ?
no, first thing i checked for seems to be coming from behind the trim between upper and lower boxes. everytime i go to dealer it decides to stop for the test drive
Upper or lower?
Maybe the door for the cabin filter was left loose or something. The lower door comes out pretty easy. I'd pull it and check.
pulled it out right away and checked for anything behind or loose cabin filter door. noise seems to come from behind the trim between upper and lower glove boxes. have taken it the dealer twice and it decides to be quite only when going there
Did you ever find the source of the rattle? Having same issue!
