Getting the Rough Country 3.5” lift, a question about tires…finished pic
wacopolumbo
Yorktown, Virginia
Hi Guys, I am getting the RC 3.5” lift when I get back from vacation. I have a question about tire size. I have a ‘22 Ram 1500 4x4 quad cab with 20” rims. I am keeping the rims. The shop recommends 34s and I don’t have a problem with that, I am just wondering how wide I can go on factory 20s without rubbing. I would like to get Ridge Grapplers (I’ve seen good reviews of them here) and am thinking 295/60r20. Will this size work without rubbing with the 3.5” lift?
Thanks for the help.
wacopolumbo
Yorktown, Virginia
Had the lift installed today. Tires on Saturday. I was concerned about the negative rake that some folks ended up with, but happily, it looks okay to me. Other than being dirty, I think it looks good. It should look better with the tires. Before pic on the left and after on the right. More pics after tires.
CHeYeNNe71
Sh*tcagoland, IL
I've been eyeing the M1 upgrade setup. They spec like the Bilstein 5100's and many claim they ride the same. Seems RC quality has come a long way over the last couple years on certain things.
mrclortho
35's will fit with proper wheels...I had to trim the rubber wheel well liner a bit but nothing a pair of snips could not handle. This s a 3.5" Ready Lift kit.
Redz72
Langhorne, PA
I have 285/65r20’s with the RC 2” struts. Actually gained almost 2 1/2” in the front after settling. 1” Motofab rear spacer lift. I have zero rub with my tires. So with your 3.5” Struts, you should have zero issues. Truck looks good brother! Love a lifted Quad Cab! IMG_9941.jpeg IMG_9914.jpeg IMG_9656.jpeg
wacopolumbo
Yorktown, Virginia
Looks bad@$$ brother! Nothing sexier than a lifted Quad Cab. You did a fine job sir.
Thank you. I was nervous about selecting the tire size. I’ve never had a vehicle lifted. Thanks to this forum, I was able to figure it out and use AlfaOBD to adjust my tire size for the Speedo.
Redz72
Langhorne, PA
@wacopolumbo
Are those factory power steps? They are sharp looking. I went with Go Rhino D6’s but might have gone your route had I seen this before. Your truck is looking great brother!
Jray22
Thanks. I went with 285/65R20.
Looks good! Probably because I have the same ride only in CC format. I’m looking at doing an identical lift except using the M1 (if I keep the truck) Also planning on adding the Hellwig rear sway bar. Could you do be a favor and measure for ground to highest point on truck? (Garage fitment) -Thanks
