Getting issues With 2019 Ram 1500 Uconnect System
sarjug
Hi, I'm new here, I have a 2019 1500 with the 8.4" Uconnect system. The system sometimes doesn't come on at all. I have to disconnect the negative battery cable and reattach it to get it to come on. Sometimes the system will reboot while I'm driving and come right back on, other times it will reboot and just go blank until I disconnect and reconnect the battery cable. Is this just a bad system that needs to be replaced? https://omegle.site/ I'm not looking to upgrade with a replacement, I just want this system to operate properly.
It sounds like there is something that needs to be checked out - this is not usual or typical behavior. (I have the same system in same age truck)
Have you tried to check the wiring harness attached? May of had a faulty installation at factory/loose connection. Sounds to me like when you're driving the vibrations/bumps are enough to make it short & reconnect. Most likely the issue, hopefully its something simple. The Uconnect systems are a easy $1500-$3000 depending on model.
