General question
Joe1979
2019 ram 1500, today stability light came on. Then later check engine light came on and also passenger head light and or the led part on the light is not working. What does all this mean in the same day?
Stability light came on because it detected a fault somewhere. Then the check engine light most likely came on in sympathy or because whatever input fault that triggered the esc light is also used by the engine computer. Those two are related, whatever caused it.
Headlight out is probably coincidence. Then again, it could be that a burnt out light triggers the BCM and that's why the Check Engine lamp came on.
Have a shop pull the codes.
Yup, have dealer run wiTECH on it and they can see what code was active/stored.
