Gauges/wiring
TWRram2500
Installing a few gauges in the truck one of which is pyrometer and I need a 12v ingition source and a source for a dimmer for the lights. Any insight thanks.
The HD trucks must be different I don't have a fuse panel under my steering wheel.
A little bit of information can be crucial. This is the 5th gen 1500 forum. You might have better luck in the HD forum.
I'm not versed in the HD's, but you likely have an inside the cab fuse panel, you have to remove 2, 7MM screws under the panel that is beneath the steering wheel and pull the panel off, and will see the fuse panel.
