Gas tank issue (Question)
abranchizio
I used to own a 2020 Ram 1500 Sport Laramie 2WD and put 40k miles on it, It had the 5.7 Hemi. When I was empty, I could put up to 25 gallons in it. I now have a 2020 Ram 1500 Sport Laramie 4WD and now when I fill it from empty, it shuts off at 17 gallons. Yesterday I was able to get it up to 23 gallons by going very slow and shaking the truck so it is a filling issue, not a volume issue. What could be causing this and how can I fix it.
BowDown
Frisco TX
There's 3 fuel tanks, the 33 gal, 26 gal and 23 gal. All have a 3 gallon reserve so unless you drive it past the low range warning, you'll be able to refill with 30, 23 or 20 gallons of fuel
abranchizio
According to window sticker, mine has the 23 gal tank. My 2wd window sticker does not say tank size.
