Full led headlamp
jkoenning
My driver's side turn signal says it's out and then the whole assembly went out then three days later the headlight started working again. It is dim and from time to time the other lights flicker or flash for a second. Was going to replace the whole thing but it's backordered everywhere but what are the chances it's just the ballast control module? Just need some advice cause it's pretty frustrating and it's expensive through the dealership.
And the cost is about $2K for a headlight module. I replaced a LED Taillight on my 2021 w/Blind Spot the MSRP at the dealer is $1230.
Malodave
Malodave
Yeah dealer wanted 952 but i don't have the blind spot monitor but I think the ballast can be replaced but not sure
I recently started experiencing almost the exact same issue. But it’s both headlights. Did you find anything out about the BCM?
Are the led headlight assemblies deferent between blind spot and non blind spot?
