First e-torque Hemi being tracked at fuelly.com. 19.6mpg 50% city/hwy mix. Not bad.
http://www.fuelly.com/car/ram/1500/2019/roamer402/828276
Some in the US are paying that. Where I am on the left coast its more like $1.02 USD/liter ($1.33/liter CAN).Damn I just converted to my numbers and damn you are paying 68 cents a litre.![]()
I myself have found modern engines don't appear to have a real break in. I've tracked fuel mileage as accurately as I can on 3 vehicles since new (gassers and diesels, topped off to same'ish level each fill, using GPS corrected odometer readings, odometer correction factor recalibrated with each new set of tires, etc. etc.).I’m sure it’ll get better as it breaks in as well.
I'm still only seeing the single e-torque hemi posted at fuelly.com. Are you sure you picked the "5.7L V8 ELECTRIC/GAS" category?I just posted mine up on fuelly but I did a bunch of towing mixed in. On the bright side my towing mpg was pretty good considering I was going up and down hill a bunch in traffic. I'll be curious to see what I get just driving normal and on mostly highways.
I agreeI myself have found modern engines don't appear to have a real break in. I've tracked fuel mileage as accurately as I can on 3 vehicles since new (gassers and diesels, topped off to same'ish level each fill, using GPS corrected odometer readings, odometer correction factor recalibrated with each new set of tires, etc. etc.).
None had a statistically noteworthy increase/decrease in mpg through their lifetime. My current diesel, first 30 day average was 14.8mpg, now 12 years/120K miles later average is 15.2 (attributed to a change from 75% city/25%hwy to a 40% city/60% hwy daily commute). Still gets average 12-13 city, and 21-22 hwy like clockwork. Towing/hauling is all over the place depending on whats in or hanging off the back of course.
I'm actually a hemi straight gas.I'm still only seeing the single e-torque hemi posted at fuelly.com. Are you sure you picked the "5.7L V8 ELECTRIC/GAS" category?
Okay cool. It's a fuelly etorque mpg thread, so just anxiously awaiting more etorque numbersI'm actually a hemi straight gas.
Okay cool. It's a fuelly etorque mpg thread, so just anxiously awaiting more etorque numbers! So far on fuelly etorque has a 4mpg advantage over straight hemi (but statistically of little significance due to the small sampling). I am going to guess as more data is accumulated, etorque real world advantage will be a consistent 2-3mpg.
Interesting. How was that boost tracked? If it's anything but hand calculated using corrected odometer readings, it's most likely inaccurate (...and forget about fuel LOM'sI’ve seen an average 2-3 mpg boost once broken in on all vehicles.
Okay we have a second etorque being tracked on fuelly. 2019 1500 stats so far:
Hemi (standard) = 14.78 mpg (US) over 33,860 miles miles tracked
Hemi (etorque) = 18.12 mpg (US) over 1,943 miles tracked
Going to be interesting if the 3.3 mpg gap increases or decreases as miles tracked increases (but I am holding to my 2-3 mpg swag lol). Based on my own experience and usage, not idling at every extended stop is good for ~1.5 mpg savings, so the rest of the increase appears to be coming from using etorque for the off the line start before the Hemi takes the reigns.
My next truck money is going to whoever has the best mpg V8 (and a big tank option), could etorque be it?
