Fuel Door
Jimmyc
2020 Ram 1500, less than 1,000 miies.
Anybody ever have the fuel door stick ( wont open )
if yes how did you fix it J
Welcome to the forum , I haven’t had that happen . I’m assuming since you said under a 1000 miles that you’ve already filled it once .
Is a spring loaded mechanism, maybe some debris somehow got stuck in there. I'm sure you probably tried to push it in multiple times, I would try one more time then call the dealer for them to figure it out.
I have found that if you push on the door right where the latch is that It will open. But if I push on it any other place it usually will not.
