Cmiller18y
- Jan 19, 2019
Wonder if I even have it? I need to check my window stickerProblem with removing that(retractable air ****) if equipped is codes and/or lights on dash. Idk as I haven’t unplugged it and tried. I do know grill shutters malfunction = engine light and codes. Would assume the same of air dam.
Yeah it's there ;(^^^ just look underneath the truck. If it’s there you will see it
Ah as in just pulling the "lip" off but the brackets continue to move?I haven’t looked at mine. Maybe away to remove the dam without whole mechanism
I plan to look tomorrowI haven’t looked at mine. Maybe away to remove the dam without whole mechanism
A guy in the vararam thread removed his without issue I believe. He documented it pretty well.Any update on this?
Not meaning to jack your thread BUT..Is that your truck in the pic??..if so what size tires are you running on those stock wheels? Is the truck lifted or stock height? 4x4 or 4x2?...thanxHas anyone removed their front valance/air dam? I'm thinking the lower body lines would mesh perfect. Just wondering if anyone has pics of it. Not worried about the wind deflection because I drive only city in it.
Can you link the thread? I’m interested in thisA guy in the vararam thread removed his without issue I believe. He documented it pretty well.
Seems Loke they’re talking in the grill, I’m talking the one under the truck!![]()
Vararam Air Grabber intake installed
Photos that might help Air through the grille, hits the shield, goes up and sucked into filter. And the mopar one.5thgenrams.com
Post number 30
