Front high with leveling lift
Spears
My front sits slightly higher than the rear with the leveling lift. I bought it used with the lift installed.
I was planning to remove the front spacer for an extended towing trip And then maybe install something different later. When looking at what’s installed it does not appear to be like common spacer kits. It looks like I have to compress the spring to remove. Also I would need the original spring cap.
can anyone confirm what this is from the pic? As shown it does not have the bolts going into the top of the shock mount, only the bolts coming out the top Into the frame mount.
