Front end noises
I don't believe so. Mine has started making that noise, it didn't always do that. I notice it going over minor bumps with brakes pressed, same bumps with no brakes pressed and no noise.
I stand by my earlier statement.
Different case perhaps.
Look at his video, how the pads are fighting the rotors trying not to turn.
The video doesn't show anything to me.
You think if I hop in 10 different brand new trucks at the local ram dealer, hold the brakes and turn the wheel, they're all going to make that noise?
At 26 seconds it is obvious that the tire is "jumping" when viewed in full screen.
Nope. My truck does not make that noise, it is not modified either.
I don't see anything obvious. It's not 100% smooth perhaps but I wouldn't call that "jumping" either 🤷‍♂️
Ok but that was my point, you said "working as designed" in a previous message which is what I disagree with, regardless of what is actually causing the noise.
Don`t get stuck on "working as designed" It is doing what is does.
So, jumping might have been a wrong way to describe it, the tire is resisting rotation, till the brake pads can not hold it still, then it rotates, with a jerking motion correlating to the noise.
Look closely, it is pretty obvious.
Not going to see it on a phone or a laptop.
Clear as a day on my 43 inch 4k monitor
ok, mine makes a weird. Noise to feels like a little clunk or something when turning from front end. I will send it next week to suspension /mechanic get it sussed out could be a ball joint. I thought this might be common when you get a lift kit ??? definately annoyong though
