Front and Rear Leveling
jadams20rebel
I am about to put a 2" leveling kit on my 20 Rebel. I am going with a preloaded leveling strut. So two questions: how will this effect the 1" lift that comes factory on the Rebel, and do I need to put any type of level on the rear?
jl13
boyle heights, CA
factory springs give you the factory 1' lift - if your kit will replace the springs you would only get an additional 1" of lift from your current set up/height.
And you wouldn't need anything on the rear - you would probably still end up with some rake and some like a bit of a rake if they tow or carry heavy loads
