808BigHorn
- Feb 22, 2021
I've been running a Readylift 3.5 SST lift on my 2020 Ram 1500. Truck was a dealer demo with the lift already installed with 33" tires when I purchased it. I immediately replaced the 33"s with 35" Grabber X3's and replaced the factory rear coils with Dayton CargoMaxx XHD variable rate coils to accommodate a 240 lb. SmartCap Evo topper and my camping load. I still kept the Readylift rear spacer to retain a factory-like rake which leveled out with approximately 900 lbs in the bed. I was somewhat satisfied with the overall ride with that setup, but was looking for ways to upgrade the front suspension (waiting for Carli or AEV to come out with something). I finally decided to pull the trigger on a set of Fox 2.0 coilovers. Eliminated the stock front shocks and the Readylift preload spacer and replaced with the Fox coilovers set at 2", while retaining the Readylift strut extension and of course the Readylift tubular UCA's. The same height was retained (25" from center of hub to fender) and aligned to well within specs. Ride is a lot better on road - can't wait to take it off road.
