Hello all,
I have removed my front bumper to put in an ADD replacement. Does it sounds reasonable to wire in lights (in this case Rigid) in the light bar cut out and attach them to the fog light circuit? In this case I am not installing a full light bar so I suspect the amps are similar and no fuse replacement would be required.
When I plug in the harness the front parking sensors work (and 'service' comes up if its unplugged), so that portion of the circuit is fine. Unfortunately the fog light button doesn't power up the Rigid lights nor light in the dash. I didn't verify working fog lights before pulling everything apart either.
thanks
thanks
