Fog/driving lights quit
JokerJay
So I have a 2019 Ram 1500 Big Horn and my driving/fog lights jus randomly both quit. They still indicate on the dash when off and on but they do not come on. I have disconnected battery and reconnected it but didn't work, looked at fuses but not labeled very easy to find right fuse. Can someone please help me with this? Also is it connected to my cornering lights cause they do not work now either when turning at night? Thanks in advance!
Not going to find any dedicated fuses to individual lights, they are controlled and or powered by the BCM. On my 2019 rebel the F49 , interior PDC, feeds both of the LED housings but does not power the fogs.
Also, your fog-lamps serve as your cornering lamps.
The left headlamp and the fog lamps share a common ground connection, G922A. The right headlamp uses G924A.
You get any DTC`s with a scan tool?
