Idk man. 4 screws and it's removed. May as well not even lock it with that imo.
Looks right.I found these. I will need to do some comparative research. What do you think?
316 Stainless Round Locking Slam Latch with Egress Lever, 2" Cutout
316 Stainless Steel CastHigh polish finishLockingEasy lift handlewww.marinedepotdirect.com
You probably need to pull an original latch, and see if measurements work, as in thickness of door, and depth of the latch itself.I found these. I will need to do some comparative research. What do you think?
Thanks for the info and "or something."Looks right.
Check this out too, from Amazon.
What are you planning on locking up in there? A handgun or something?
I was just curious, as I have tried to fit tons of things in there, and it's always "just too short".Thanks for the info and "or something."
