Hemogoblin
- Dec 16, 2019
So the rear glass frame had 2 cracks and that was leaking and replaced. Headliner stained and light was leaking.
When I removed it, the gasket was toast. Cleaned off all the old glue (used a dish sponge with the rough end and a cloth, kept both wet with xylene bit found that acetone worked best and smells a lot less). Once cleaned, I applied a nice rope bead of plumbers putty. Put it all back, tightened it up, and it leaked, LOL The plumber putty would work but it is so pliable, it dipped down as the light was being seated so there was an opening at the top (unsealed) and it allowed water through. Took it off and was going to apply a seal and peel removable caulk but instead decided on a rubber weatherstripping that I grabbed from Depot for like $10 Canadian.
Nice and fat, did a water test and no leak with a hose blasting away.
Hope this healps anyone with the same issue.
