[Fitment Help] 24x10 ET+25 on ‘19 RAM Limited w/ Air Ride + 35x12.5 R24 Tires
SwissRamDriver
Thun
Hey everyone!
I’ve got a ‘19 Limited with air ride and no additional lift.
I’m planning to run my 24x10 wheels (atm with shady 295/35 R24 tires) with +25 offset and 35x12.5 R24 Radar Renegade R/T+ tires. I’m a bit unsure how the +25 offset will affect clearance.
I also have 34mm spacers, which would bring the effective offset to around –9, but I’d need to trim the studs since the 24s don’t have cutouts.
Has anyone run a similar setup, or know if this could work with just minor trimming or adjustments like shown in some other threads?
Hey everyone!
35s won't fit on a stock limited. I also have a 19 limited on-air ride and run a level/lift. truck also equipped with the ORG (off road group)
the spacers will help so you dont rub UCA but the larger tire will rub 100%. i bought my truck stock no lift level with 34s and it rubbed all the time not just full lock or reversing etc
Alright. One answer. Anyway..
I post pictures in case someone wants to see them.
No issues at all. Small adjustment needed (2-3min of work). Removed the small plastic flaps and it fits very well.
+ Selfmade Leveling kit for front for 30$
