FitCamX Dash Camera Install
RAMMER80
I helped a buddy choose and install a dash cam in his 2022 Bighorn.
Went with the FitCamX 4k. Front only. Took about 15 minutes to install by taking our time. Zero issues. Looks absolutely factory.
We noticed you need to disconnect from the truck WiFi to connect which is no big deal.
A tip for anyone installing one of these or some other is simply removing the plastic shroud installed from the factory….
After you remove the first thin piece at the top and you get to the bottom piece, a simple way to remove. It is to push the plastic to the passenger side and it will come off. Don’t pull directly down.
It’s also a good idea to use a zip tie, so the harnesss does not bounce around and cause noise when driving.
Quality from the video seems good. Yes there are much better ones out there as far as video quality getting in the $300-$500 range but you’ll have to deal with ugly wires and it will not look factory like this one. Any day of the week I would rather have something look OEM vs aftermarket.
One more thing when you purchase it, make sure you get the correct one because it comes in a A configuration or a B configuration. You can see which each of them look like on their website or an Amazon.
Nice write up. There is a thread with about 30 pages devoted to the Fitcamx. Check it out:
Thanks. I noticed it about 30 seconds after I posted.
