Fit Problems With Huskyliners Xact Fit In Rear
Chipman
I returned my first set to Huskyliners even though I bought them on EBay because as the photos show they are way off. Just received the new ones yesterday and they are identical to the first set. The fronts fit fine but the rear liner simply does not conform to the contours of the Gen 5 crew cab. I’m not usually that picky but for $209 I expect a lot more. Anyone else had this problem. I’m about to order MaxLiners and call it a day.
Looks like they "fit," just poorly. Any reason you didn't buy the Mopar slush mats? They fit well from what I have seen. And cheaper than the Husky liner.
Yea, the ends may need some time to flatten out. That said my moper slush mats fit like a glove and very happy with them.
The Mopar mats fit very well, look great and are made of a more flexible material so they conform to the contours of the floor.
I bought the xact countour, they initially had a small hump in the middle as if it was made for something older. Although it didn’t look as bad as yours. After a couple days in the truck in the heat settled out fine and no issue. Fronts were perfect out of the box.
I loved the Xact Contour mats in my F-150... so I'll be ordering a set for my RAM. That said, give them a few days in the sun to flatten out, they'll be just fine. My Xacts did the same thing.
-John
Get the Mopar slush mats...they're awesome
I had the same problem. I ordered the husky xact fit when I first got my truck because I loved them in my last Ram but they definitely aren’t the same quality or fit so I sent them back and ordered the mopar slush mats very happy with them very good quality and fits perfectly
They definitely look good and after seeing those photos my decision is made. Tell me about your underseat storage. Is that factory or something you added yourself?
Get the mopar oem mats. Fit perfect.
-John
A big part of the problem is that the recesses in the liners that are supposed to accept the floor pins and hold the mats in position are large and oval whereas the actual pins are smaller and round. Not only that but they are spaced about 1/2 to 3/4 inch too wide. This results in a big wrinkled hump in the center when the pins are in place.
