First time buyer
scottdvr69
Been a Silverado owner all my life, this is the first Ram 1500 Big boy 2024 ... Love the performance. When i back up I get this ibeep alarm inside the vehicle. Its very annoying . Help if you can please
O'Town Ram
I know less and less about more and more
Orlando, FL
Congats on the new truck. I would like to get rid of the beep myself.
Eighty
Moderator / Dream Killer
If you’re talking about the backup sensors, you can turn them off with a button on your center stack. Yours may be in a different location, but it will look like this.
scottdvr69
the sensor that warns you that your backing into something beeps and will stop your truck. This funtion is on my 12 inch display screen. When turned off it still beeps.
scottdvr69
thanks.. The display screen has the option to turn it off but the beep still engages when backing. You have the option to turn the beep volume down, but its still lound and annoying.
Eighty
Hit the button I circled. The option you turned off is the braking component, but the sensors still beep at you until you turn it off.
go-ram
thanks.. The display screen has the option to turn it off but the beep still engages when backing. You have the option to turn the beep volume down, but its still loud and annoying.
Poster "Eighty" is correct. If you turn off the Rear Cross Path braking via the hardware switch on the dash, not the touchscreen, it stops all warning noises and braking when backing. On my 2020, right next to the Tow/Haul switch
I turned mine off using the hardware switch on the dash the second day I owned the truck, it has been off to this day and will be off as long as I own it. Note that when turned off, those switches have an orange LED constantly lit.
