Falken Wild Peak AT3 ?
Is there a high risk running 275/60R20 Falken Wildpeak AT3W (115 max load rating) on my Big Horn 4x4 with standard suspension? Stock tires it came with are Goodyear Wrangler Fortitude HT (116 max load rating). Someone on this forum has done it before and mentioned his Ram came with Bridgestone Dueler (114 max load rating). Was looking to purchase, but the tire specialist advised against it because of the decrease in max load from my factory tires. Won't be towing anything or hauling much.
No problem at all.. They are what I use for the winter on my stock limited wheels. I purchased them from Amazon lowest price I could find.
Thank you for your reply. This is likely what I will go with since it is cheaper and closer to the rev/mi of my stock Goodyear's than the 275/60R20 Nitto Ridge Grappler XL.
