Posted a picture of how to pull wheel well liners in case you can’t figure it outMy truck didn’t come with bed lighting. I bought the Mopar bed light kit and this is the exact same place they show you to run the wire in. To access it ,you need to pull the drivers side wheel well liner off . There is a little rubber molded plug you need to cut off with some side cutters. As far as wire size the 2 , 14 ga wires pulled through easily, it was a struggle to get the wire through the grommet once the wires merged into one by myself . Finally had my kid pull gently while I fed it through.
Probably about 3-4 16 gauge wires, if you're determined enough I'm sure you could fit more.Anyone know what size wire can be fit thru this?
It will stretch to fit quite a bit. I ran the wiring kit for my ARB fridge through the grommet. Dual 8 gauge wires. Used a little soapy water and was easy. Also, I did it without removing the wheel well liner.Anyone know what size wire can be fit thru this?
Thanks! I'll check for that tomorrow!Another Gem while perusing the instructions for the Remote Start Accessory! Ram gave us an open grommet location behind the battery on the firewall to pull at least one wire through the factory grommet:
Can this be accessed without pulling the wheel and/or inner fender well off?Another Gem while perusing the instructions for the Remote Start Accessory! Ram gave us an open grommet location behind the battery on the firewall to pull at least one wire through the factory grommet:
I put no 4 with a little soap dishwashing soapAnother Gem while perusing the instructions for the Remote Start Accessory! Ram gave us an open grommet location behind the battery on the firewall to pull at least one wire through the factory grommet:
I didn't see this on my 2021 limited either...I realize this is getting close to a year old but I have a new Ram, 2021, and I don't see these spot so I am guessing they have changed things up with this?
