Extra switch
brental1
Hoover, AL
In the process of swapping a leather dashboard into my truck, I discovered this cavity for a 3rd switch on the e-brake, adjustable pedals panel. Can't find any mention of it in the operator's manual. But, seems like it would be a cool switch to add. What's it for?
Will the connector you removed from the back of the pedal adjustment switch fit there? Looks like a holder for the pedal adjustment switch harness connector in case the truck didn’t come with that feature.
The extra switch in there is for the 115Vac outlet in the truck bed.
Interesting. I never knew there was a switch in the cab for an outlet in the bed. I found pics of the panel with the switch in it. It appears that if you have the switch, it requires a different panel since the switch is recessed into the front of the panel and snaps in.
