Tabascocat
- Dec 29, 2020
Under the backseat, there is a pulley attached to a tension wire that comes out a bit. I know it is for the storage flap that folds out and goes through the little slit. Here is where I am stumped, along with many Ram dealership employees..........
The storage has two position:
1. Pushed UP
2. Pulled DOWN
This wire doesn’t come out far but I don’t think it is needed when extended storage(lowered down) is in use, i.e. pulled out. But, when I try to bring it up, it hits the front of the seat brackets and will not go any further, it also will not go over the top of them. This will not allow for the pulley wire to go through the slit then turned sideways to hold it.
I have had several mechanics and service employees look at it and no one can figure out how it is used properly. There is an upper hole to the back on each side mount plate that appears to be the same as the lower front holes that it is connected to. We tried to move each side to those other holes but could not get it disconnected without risking breaking it.
Why is this pull handle thing even there if it does nothing? To reiterate.....there is a long L-shaped rail thing from one end of the cab to the other under the backseats. It swings up or down and when swung down, it gives extra storage space but it only swings up so far, hits the seat rails as it doesn’t sit flush....it is at an angle with not enough room for the pull handle to go through.
We looked at more 20’ and 21’ models on the lot today since I was awaiting an oil change. Every truck had the same proble, no one knew how to use it properly. Any help would be much appreciated on how to use this feature.
1. Pushed UP
2. Pulled DOWN
