Joker90048
- Jun 28, 2025
Won’t effect my gas mileage and I posted another picture don’t know if it helps it’s under the passenger back doorNeed more info. Where is that connection? And are there threads cut into that flange? It might not need a nut.
Generally, nothing should come out. But if that's after the rear O2 sensor, it doesn't matter. It'll just be louder than it should be, and probably not by much. There will always be some moisture in the exhaust. Water vapor is one of the products of combustion.
Sorry that first part was a questionWon’t effect my gas mileage and I posted another picture don’t know if it helps it’s under the passenger back door
Sorry no idea what that means I feel air when it’s running and water drips out that’s ok?Flange is threaded.
