Exhaust Manifold bolts and gasket
scottamj
My 2021 Ram 1500 E-Torque suddenly had a loud exhaust noise. I didn't hit or run over anything. Checked the muffler and exhaust and found no leaks. I took it to the dealer since I have 56,000 miles and also the extended warranty through the dealer. Dealer called to say the exhaust manifold was leaking due to a bad gasket caused by 2 broken bolts. There has been no damage done to the exhaust by me and the dealer let me know that the gasket was covered but it cost me $200 for the bolt replacement! Ridiculous that the bolts are not covered.
Do a search and you will see this is a common issue.
I had a exhaust leak when cold, My dealer replaced both manifolds, gaskets and all bolts with zero cost to me. This was done at 59,500 miles
what they are saying sounds like crap.. i would call your extended warranty company..
